Timing Gear Change
Old Mar 5, 2005 | 05:39 PM
Longhair's Avatar
Longhair
Default Timing Gear Change
[:@] I'm changing out the timing gear and chain set for a 1987 Dodge Dakota V-6. The manual instructs me to align the gear set as follows. The crank gear with timing mark in the 12 O'clock position and the cam gear in the 6 O'clock position. I looked at the current gear configuration before removal, and the cam gear is positioned in the 12 O'clock position. Now the manual I have is for 87 thru 96 but the vehicle manufacture date on the door panel reads 10/86. Is there a differance?
Old Mar 5, 2005 | 06:03 PM
horatio102's Avatar
horatio102
Default RE: Timing Gear Change
perhaps try the Dakota section.
