Two questions...
Old Apr 10, 2009 | 02:54 PM
charlie1935's Avatar
charlie1935
The one on the top of the housing was only about six inches long, and had some kind of plug in it that I broke. I'm thinking it's some kind of pressure release tube
Is that the breather tube for the front axle housing?
Old Jul 30, 2009 | 10:24 AM
truckfreak69's Avatar
truckfreak69
not sure? I found the actuator motor does work by applying vacuum to one side, then the other. However, when I tried to reroute the vacuum lines from the diaphram, to the transfer case actuator switch, I think I mucked something up. In 2WD i'm getting vacuum on one side, but when place in 4wd, I get no vacuum in either side. Does anyone have a routing diagram? Or know what the issue might be?
