Help.. ABS and Brake lights on in '93 D350
Old Nov 11, 2012 | 05:15 PM
SEAL's Avatar
SEAL
Are the rear shoes adjusted correctly? Is the peddle good and solid or is it spongy? How did you bleed the brakes? A bad rear ABS valve can cause the rear brakes not to work at all and that will cause excessive front pad wear.
