Problem with 83 Ram starting
Old Apr 21, 2009 | 02:03 PM
83Dodgeman's Avatar
83Dodgeman
Default Problem with 83 Ram starting
Ok so I have a 83 Ram D150 with a 318 2 barrel. When I first got it from my grandfather it ran great but for almost the last year it has had a problem starting. When I try to start it I have to crank it 4-6 times before it will start and when I get it started I have to stay on the gas or else it will kill. After it gets warmed up it runs fine and will start right when I turn the key the first time. But if I let it sit more than a few hours the engine will get cold and I will have the same problem. Anyone have any ideas? Thanks for any help
Old Apr 21, 2009 | 02:14 PM
SEAL's Avatar
SEAL
Sounds like a choke problem. What kind of choke does it have?
Old Apr 21, 2009 | 02:24 PM
83Dodgeman's Avatar
83Dodgeman
An automatic choke
Old Apr 21, 2009 | 03:09 PM
charlie1935's Avatar
charlie1935
Maybe time for a tune up?
Old Apr 21, 2009 | 03:13 PM
83Dodgeman's Avatar
83Dodgeman
I always do regular tune ups so I know thats not the problem
Old Apr 21, 2009 | 04:12 PM
SEAL's Avatar
SEAL
Look inside the carb throat to see if the choke is closing like it should when it is cold.
Old Apr 21, 2009 | 06:56 PM
moparborn's Avatar
moparborn
Do you press the throttle at all or have you tried to?
Maybe choke.
Maybe the fuel is draining out of the fuel bowl.
