Power Windows
Old Apr 24, 2009 | 01:30 PM
JMNeel's Avatar
JMNeel
Default Power Windows
So the power windows in this w150 i just bought are not working at all (both of them). I thought since they both went out at the same time (i think they didnt work when i bought them) it was just a fuse, replace it thats not the problem.
So i pulled the door panel off and there is juice going to the connections to the motor from the switch up and down...
Im assuming that the motors are bad. Just want to get your input before i buy new motors and attempt to replace them.
Thanks!
Old Apr 25, 2009 | 02:36 AM
lugnuts's Avatar
lugnuts
Hold the switch down and knock the hell out of 'em. Sometimes they stick, or the brushes get dirty. Also, got a ground from the switch?
Old Apr 25, 2009 | 08:37 AM
SEAL's Avatar
SEAL
When in doubt use a bigger hammer. LOL
Old Apr 25, 2009 | 04:28 PM
JMNeel's Avatar
JMNeel
thanks ill try the hammer thing and ill also try sending power straight to the motor, maybey its just a connection.... im not sure about the ground wire i didnt look that hard at the wires
thanks again
Old Apr 25, 2009 | 10:54 PM
lugnuts's Avatar
lugnuts
Just wondering about the ground since neither motor works. You can just whack the door with your fist and sometimes they will come to life.
Old Apr 26, 2009 | 04:57 PM
moparborn's Avatar
moparborn
If the drivers switch is bad it keep the passenger side from working due to how its wired.
Old Apr 27, 2009 | 12:22 PM
JMNeel's Avatar
JMNeel
Ok well i tried smacking on the motor with a hammer a little and that didnt help...
As for the ground I looked at the wiring and there is two wired coming from the switch (driver) to the motor, 1 up 1 down, at least that is what the test light indicated. i bought a chiltons for the truck and there is no wiring diagram for the windows in it.
where would the ground wire be?
also is there a good way to test the motor using some type of external power without taking it out of the door?
Thanks
Old Apr 27, 2009 | 02:29 PM
SEAL's Avatar
SEAL
JM
What year is your W150 so I can try to help you? There are different wiring diagrams for different years.
Old Apr 27, 2009 | 10:46 PM
moparborn's Avatar
moparborn
The motor should be grounded through its mounting or a ground wire from the motor itself,apply power to one wire then the other going to the motor.
What year and model is this truck?
It may have a circuit breaker,or?
Is it the 04 dakota?
My wifes gave us trouble,it was the lock button on the drivers door for the window,it may be in the switch.
Old Apr 28, 2009 | 11:08 AM
JMNeel's Avatar
JMNeel
It is a 1990 W150 the club cab long bed. Its not my dakota I was smart when i bought that one and got crank windows lol
SEAL if you could get me a wiring diagram that would be awesome!
Thanks for all the help guys
