Power Windows
Old Apr 28, 2009 | 03:18 PM
SEAL's Avatar
SEAL
ELECTRIC WINDOW CONNECTOR AND SWITCH FUNCTIONS
left door switch
B+ B- switch select window movement front side of connector wire position
LB WT 1 left front up 16LB 14BR
WT LB 1 left front down 12BK
BR VT 2 right front up 16WT 14VT
VT BR 2 right front down 12TN
TN BK SWITCH feed & ground
right door switch
B+ B- window movement & switch right window switch connector
WT LB down from door switch 14WT 14BR
LB WT up from door switch 12TN
VT BR down from master switch 14VT 14LB
BR VT up from master switch
TN - feed
left motor
14VT down from black connector at motor -- to 16LB on left door switch
14DG up from black connector at motor --- to 16WT on left door switch
right motor
14VT down from black connector at motor -- to 14WT on right door switch
14DG up from black connector at motor ---- to 14LB on right door switch
12BK/RD from ignition switch to fuse #2 ( a 30 amp circuit breaker)
12TN/BK from fuse to black connector (behind radio)
12TN from black connector (behind radio) to left and right door switch
12BK from black connector (behind radio) to left door switch
14VT from left door switch to right door switch
14BR from left door switch to right door switch
Old Apr 28, 2009 | 03:32 PM
SEAL's Avatar
SEAL
Sorry about first post please ignore it.
left door switch
right door switch
TN - feed from master switch
left motor leads
14VT is down function from black connector at motor -- to 16LB on left door switch
14DG is up function from black connector at motor --- to 16WT on left door switch
right motor leads
14VT is down function from black connector at motor -- to 14WT on right door switch
14DG is up function from black connector at motor ---- to 14LB on right door switch
Old Apr 28, 2009 | 03:50 PM
JMNeel's Avatar
JMNeel
Thanks A Lot! That will help a bunch! I will mess with it tonight.
Old May 4, 2009 | 10:11 PM
tooltime's Avatar
tooltime
i have a 86 d150 with power windows.they dont work.the pass switch has been replaced at sometime.the main switch works the drivers window to about 4 inches and then stops.it sometimes takes a few tries to work.sometimes the window will fall into the door.i have looked into the doors and on the drivers door i have a big plug that is not hooked up(at top of door at the back).i plugged it in and a fuse blew,cant remember what it was.what do you guys think?where is the motor at for p.w.is that what i hit-tap with a hammer.the doors do leak so can that be 1 problem.thanks
Old May 5, 2009 | 09:12 AM
SEAL's Avatar
SEAL
You have a short someplace. Unplug the connector at the switches and at the motors in both doors. Now replace the fuse. If it doesn't blow immediately plug in the drivers switch and operate the switch to see if the fuse blows. If so the problem is in the drivers switch or its wiring. If not plug in the passengers switch and operate both switches to see if the fuse blows. If not plug in one motor at a time and check the fuse. This approach will allow you to isolate the problem.
Old May 7, 2009 | 09:00 PM
rtaylor's Avatar
rtaylor
you can get replacement motors from advance, i just fixed my son's 88 drivers side window, the motor was good just had to order the gears....
Old May 8, 2009 | 11:03 AM
JMNeel's Avatar
JMNeel
Yeah i found them at autozone for about $60 but i just dont want to spend the money until i know that the problem...
Old May 9, 2009 | 07:55 PM
nickhuffman's Avatar
nickhuffman
So yah I didn't want to post a new thread about this. But im having pretty much the same problem! I let a friend borrow my truck to move some furniture and when I got it back the next day my passanger side window wouldn't go up or down. No noise no anything! I took off the door panel and the connection looked fine, unplugged and reconnected. drivers side sticks a little maybe yall can help with that too?
02 Dakota 4.7 Club
Old May 11, 2009 | 09:00 AM
Mad Mudder's Avatar
Mad Mudder
Originally Posted by SEAL
When in doubt use a bigger hammer. LOL
Or get the BFH out...lmao (I think ya'll know what that is...lol)
Old May 11, 2009 | 09:05 AM
Mad Mudder's Avatar
Mad Mudder
What is the deal when you can hear the window motor running but the window dosen't move? Could that be the gear that is attached to the window motor?
