Need a little pep.
Old Apr 24, 2009 | 02:00 PM
travixhouser's Avatar
travixhouser
Question Need a little pep.
I got a 73 dodge d100 with a 360 two barrel. auto. how can i increase throttle response. its really sluggish. also sometimes when i push the gas too hard too fast it'll backfire through the carb. can i retard the timing at all. im not looking at buying anything. and i don't want more power. i just wanna push the gas n go. tips please
Old Apr 25, 2009 | 08:25 AM
SEAL's Avatar
SEAL
A back fire through the carb always sends me to the timing first.
Old Apr 25, 2009 | 12:20 PM
travixhouser
What would you suggest to cure this problem.
Old Apr 25, 2009 | 03:20 PM
SEAL's Avatar
SEAL
Do a tune up.
Old Apr 25, 2009 | 11:03 PM
lugnuts's Avatar
lugnuts
Check the vacuum advance and make sure the diaphram's not busted, and hook the advance to a ported vacuum source. [Only has vac. when you open the throttle,passage is above the the throttle blades] See if the mechanical advance inside the dist. is stuck. If it is tear the dist apart and clean it up, lube the advance assm.
