No drainage for rocker panels
Old May 5, 2009 | 09:50 AM
81vanman's Avatar
81vanman
Default No drainage for rocker panels
On some of the older Mopars, there are plastic or rubber caps in the holes in the lower INSIDE OR UNDERSIDE body panels (above the rocker panels). I removed mine since a couple of areas were full of water. I guess this is the thing to do, but don't understand why this wasn't done at the factory, to prevent rust in the rocker panels.
Old May 5, 2009 | 12:38 PM
nemesis_SS's Avatar
nemesis_SS
i put a about a half inch of oil into my doors to stop rust, and drain it out to change it every other winter. oddly enough i dont have a plug, but i drilled a hole and tapped it so i can use a screw
