parting out 1983 d150 royal
Old May 7, 2009 | 10:03 AM
wirtner's Avatar
wirtner
Default parting out 1983 d150 royal
Well guys im giving up my truck is now being parted out the rear ends good, the trannys good as far as I know .the bed can be saved with a lil work. the frame is good last time I checked. as for the motor I pulled the oil pan and saw its the back next to last two cylnders that were thrown. the cab is good except for one hole but nothing into the passanger compartment . the only things not there is the the grill the carchole canister and a cat but the exhaust is 2 or 3 months old from manifolds to the tail pipe the exhaust is a quiet side exit in front of pass. tire, its 2 1/4 inch pipeing I think may be two and a half. there is no cat on the truck the smog pump is gone the motor is a 318 2v I think it still has a good top end i replaced the fuel pump (mechanical) the intake maninfold gasket rebuilt carb. Idont know if its still good but I replaced the oil pump too just email me on here or at wirtner36@hotmail.com with what you need and il give you a price. thanks for all your help wirtner
