fan clutch removal
Old Mar 12, 2005 | 04:34 PM
roy's Avatar
roy
Default fan clutch removal
does anyone know how to remove the fan clutch on a 88 ram 50? I am trying to replace the timing belts. I removed the fan and the 4 bolts holding the clutch assembly on but it will not budge. Do I have to take the clutch apart to get to the bolt that holds the water pump pully on?
Old May 21, 2005 | 08:56 PM
Rampant 150's Avatar
Rampant 150
Default RE: fan clutch removal
Im not sure but it may be a screw on type fan clutch. If it is, then there should be a place to put a large wrench onto the shaft. You then need another tool to hold onto the four bolts on the pulley to keep it from moving. You have to keep the pulley from turning with one tool, and loosen the fan with the other. Sometimes they are right hand thread, and sometimes they are lefthand thread, so if it doesnt loosen in one direction, try the other. You should be able to get the tools needed in a set at most auot shops.
