installing thermostat
Old May 17, 2009 | 03:27 PM
tooltime's Avatar
tooltime
Default installing thermostat
i am going to put that on in a day or so.how much antifreeze should i drain?how much will come out of the plug a little or a lot?how do i take the plug out,loosen?use pliers to turn the bolt till some antofreeze comes out?antthing else i need to know?thanks
Old Jun 10, 2009 | 10:59 PM
durec's Avatar
durec
Default Thermo Replacement
usually I also flush the radiator when I change thermo's.....so I let all of the coolant drain, flush, install thermo and new gasket , tighten back up drain screw...fill her up and let her run for about 30 minutes to make sure you don't have any leaks and also ck to see if new thermo operates properly
Old Jun 17, 2009 | 10:28 PM
ssloco2001's Avatar
ssloco2001
all the anti freeze that comes out is just whats in the hose. just pull the thermostat and replace then mop up on top of intake
Old Jun 18, 2009 | 12:37 AM
charlie1935's Avatar
charlie1935
It will also come out of the manifold where the thermostat goes there by leaving the radiator low.
