smog pump and battery cable q
Old Jun 1, 2009 | 07:42 PM
tooltime's Avatar
tooltime
Default smog pump and battery cable q
truck is a 86 and it has that smog pump stuff that is not hooked up.i want to remove it but i am not sure what to do with the neg battery cable and brace on the back(has 2 springs connected)?where can i put the cable and what do i do with the brace?anybody with pic of 1 removed(smog pump) thanks tooltime
Old Jun 1, 2009 | 10:34 PM
moparborn's Avatar
moparborn
Take a look at my pics of my engine in my gallery.
You can bolt the ground to the front of the head and use a simple bracket for the springs.
Old Jun 8, 2009 | 06:42 PM
crazzywolfie's Avatar
crazzywolfie
if you do bolt it to the head clean the metal around the hole so that the connection does not overheat and not start once and a while. you could just use a nut and bolt to the emission pump bracket. did that with my truck.
