Need part: Alternator wiring harness
Time to practice??? Get everything clean, get the right heat and use rosin core solder..........practice, practice,practice. A lifelong skill you need.
You could also use those crimp on connectors, although they are in my bag of last resort. Under the hood they corrode and cause problems down the road.
Here's a little practice exercise........take a soup or bean can and open it out flat. Clean it really well then practice soldering "dots" on it, about 1/4" in dia. When they look smooth and bright, move on to "tinning" short lengths of stranded wire ends. When they look good, take those ends and solder them on to your "dots". This will allow you to see how much heat and where it is needed to make good mechanical and electrical joints. Everything should look bright. If it looks dull.....not enough heat. Practice, practice, practice.........just like a lot of other things.
