Good Tranny rebuild Manual?
Old Aug 17, 2009 | 07:36 PM
67Fargo's Avatar
67Fargo
Default Good Tranny rebuild Manual?
Hey just wondering if anyone has any good recomodations for a good tranny rebuild manual for our trucks. Mine is the 727. Thanks
Old Aug 17, 2009 | 09:43 PM
lilredex's Avatar
lilredex
Start here: http://www.transmissioncenter.net/727transmission.htm
If you want step by step, check out these:
A) Mopar factory manual
B) Carl H. Monroe's book "Torqueflite A-727 Transmission Handbook" ISBN 1-55788-413-7 http://www.themotorbookstore.com/tor...nsmission.html
C) ATSG's Manual A727/904 http://www.700r4l60e.com/store/produ...?productid=229
D) Petersen's "Dodge Pick-up Repair" ISBN 0-8227-5043-0 http://www.bookfinder.com/dir/i/Dodg...ir/0822750430/
Get them all.............good references
Old Aug 17, 2009 | 10:14 PM
crazzywolfie's Avatar
crazzywolfie
you should find out how much it would cost at the local transmision shop to do because it might be easier if you don't know what your doing. i just thought about this you should check out davidsfarm on youtube he did a couple of videos on transmisions. http://www.youtube.com/watch?v=ydlRegFEaIk
Old Aug 18, 2009 | 04:24 PM
SEAL's Avatar
SEAL
Go to your local library and find your tranny in the professional manuals they have there. For about 2-3 dollars at the copy machine you will have complete detailed instructions on your tranny. The problem with auto trannys is not the knowledge needed to repair/rebuild them it is the cost of the special tools that you need.
