A/C pulling down engine
Old Aug 26, 2009 | 04:07 PM
newtcopa's Avatar
newtcopa
Default A/C pulling down engine
When I use the A/C it really pulls the heck out of the engine. There is a noticeable difference in performance and power. It is also much slower to start. Is that normal in a 1982 D150 with a 318 and single barrel carb?
I have driven it 3500 miles now after tune up, new carb, A/C conversion. I recall the mechanic saying the A/C was a little noisy but working ok.
It cools the truck but it isnt freezing anybody out!
Thanks.
Old Aug 26, 2009 | 04:35 PM
kev2's Avatar
kev2
1982 been a few years memory is fuzzy.
this is a carb engine?
is idle adjusted corredt....if applicable idle sp solenoid ?
what is A/C pressure BOTH high and low???
it is using R12 still? cnverted to R134a?
Old Aug 26, 2009 | 05:57 PM
crazzywolfie's Avatar
crazzywolfie
single barrel carb? are you sure its not a 2 barrel carb. if it was a singel barrel carb that would be your problem. in 82 those 318 trucks came with 2 or 4 barrel carbs.
Old Aug 26, 2009 | 06:47 PM
newtcopa's Avatar
newtcopa
yea it was converted to new ac and the mechanic put a new single barrel on it. ....it runs 70 mph fine, but is a little doggy in town. wish it had better pick up. switch carbs?
Old Aug 26, 2009 | 07:03 PM
crazzywolfie
if you had the proper 2 barrel carb you would not get that pulling.
Old Aug 26, 2009 | 07:31 PM
rwb's Avatar
rwb
You need the correct carb, it should be a 2 barrel and also check to see if your ac solenoid on the carb is activating to up the idle.
Old Aug 26, 2009 | 07:35 PM
newtcopa's Avatar
newtcopa
thanks. I will get it changed.
Old Aug 26, 2009 | 08:02 PM
crazzywolfie
i would fire my mechanic if he even sugested putting a 1 barrel. my mechanic wants to put a 340 highrise intake and a 4barrel carb on my 318.
Old Aug 26, 2009 | 09:30 PM
newtcopa's Avatar
newtcopa
I agree. I had a two barrel, rebuilt from oreillys, he said he couldnt get the choke set right so he put on a single barrel without asking. I wanted a four barrel and he told me about the intake, gas mileage, etc. blah,blah,blah.
Old Aug 26, 2009 | 10:12 PM
crazzywolfie
if he can't set the choke i wouldn't consider him much of a mechanic. i would tell him to put the 2 barrel on so that you can take it to a real mechanic.
