rear tail light wire nightmare
Old Aug 30, 2009 | 08:03 PM
crazzywolfie's Avatar
crazzywolfie
try touching the wire that was cut to anything that is grounded. make sure you have the lights on and if it works then you just have to keep it grounded. if it doesn't work then you need to find a positive wire to run to it.
Old Aug 31, 2009 | 05:32 PM
SEAL's Avatar
SEAL
You will just have to use a multi-meter or a test light and find a wire in the harness that is hot when the parking lights are on. Wire the center bulb contact point wire to that. The other wire goes to a good ground.
Old Sep 6, 2009 | 12:08 PM
power ram's Avatar
power ram
well I fixed the tail lights and the license plate works!! The battery wont hold a charge though It wants to fire up but not enough juice.
Old Sep 6, 2009 | 02:07 PM
crazzywolfie
dodge trucks seem to really like there juice. i leave mine on trickle charge all the time. hopefully it will extend the life of the battery.
