Help crankshaft position sensor change?
Old Sep 5, 2009 | 04:07 PM
bobs92ram's Avatar
bobs92ram
Default Help crankshaft position sensor change?
I just bought my 92 1/2ton with a Magnum 318. The CPS needs changed. I have tried swivels with a socket from up top. And wrenches from underneath. The only other way I see is to remove the passengers side motor mount to lower the motor a little. I need to buy me a book. Any suggestions, or how did you did it? Thanks.
Old Sep 5, 2009 | 09:09 PM
crazzywolfie's Avatar
crazzywolfie
are you sure the cps needs to be changed? acording to the haynes manual it is a fair bit of work.
