1993 dodge w350 pcm
Old Sep 5, 2009 | 06:25 PM
gavinladut's Avatar
gavinladut
Default 1993 dodge w350 pcm
i have a 1993 dodge with a 360 and auto tranny my pcm is acting.will the pcm work from a 1995 with the same motor and tranny
Old Sep 6, 2009 | 07:57 AM
SEAL's Avatar
SEAL
Each year, including 1993, vehicles of the same year, same engine, and same tranny used several different PCMs. The only way to know if a swap will work is to compare the part numbers. The part numbers are on the outside of each PCM.
Old Sep 8, 2009 | 12:59 AM
Hahns5.2's Avatar
Hahns5.2
I replied to your thread on Pirate4x4 so I'll post it here too.
I know you can on the Dakotas, not sure if the generation change between 93 and 94 Rams changes anything. The Mopar PCM in my 5.2 Dakota is for 94-95 5.9 auto RAMs and the guy I bought it from was using it in his 93 Dakota without any problems if that helps.
