Miles per gallon- What are you getting?
Old Sep 6, 2019 | 01:17 AM
  #291
xd6jkc's Avatar
xd6jkc
Thumbs up 1st gen 1990 Cummins
250,000 miler. Still get 20-22 mpg. Pulling my 22' travel trailer from the 70's, it drops to 14-16 mpg.
Old Jun 13, 2020 | 09:23 PM
  #292
rwaltemate's Avatar
rwaltemate
1993 W250 regular cab and bed with the 360 (5.9L) and it gets around 10 mpg.
Old Mar 29, 2021 | 01:33 PM
  #293
Sweet5ltr's Avatar
Sweet5ltr
1977 W200 (M880) with 318 LA / 727 (full time 4WD). Holley 600 (4160), Edelbrock Performer intake manifold, Summit 6901 camshaft, Longtube Headers. 10 - 11 MPG highway @ 2,800 RPM w/ 4.10 gears & 33" Yokohama Geolandar M/T's. Around town I imagine anywhere between 8 - 12.
Old Dec 18, 2021 | 10:38 PM
  #294
Maki's Avatar
Maki
88 Longbed 2WD. Wood bed made out of pressure treated wood from HD. Weighs more than stock bed. 32” Toyos. 3.9l with smog pump deleted, straight piped and a bunch of vacuum lines snapped. Getting 15-18mpg currently.
Old Jul 18, 2022 | 08:35 PM
  #295
Dodger2050's Avatar
Dodger2050
8-10 in the city havnt really taken it on the freeway 10-11 driving back roads which is what I mostly drive
1986 360 single cab long bed
basically stock motor with custom 4in exhaust
any suggestions for better mpg?
Old Jul 24, 2022 | 04:48 PM
  #296
Mika7536's Avatar
Mika7536
14.5, 14.9, 13.75, 13.9, 14.5, 13.8, 16.4, 14, 15.2, 15.8, 14.5, 15.9, the past couple of times I've filled up and checked the milage.
1989 D-150 3speed automatic, 318, TBI, LWB, 139+ thousand miles. All smog, EGR and such still hooked up and operational. 15" tires as stock and as original as it was when new, as far as I can tell. I believe I am the 3rd owner. It was originally bought second hand from a dealership and used to tow a camper. It still has the brake assist assembly hooked up.
Old Jul 28, 2023 | 01:41 AM
  #297
JXTNSADVNTR's Avatar
JXTNSADVNTR
1993 Dodge W150 Clubcab w/5.9l 360 Magnum and NV4500 5-speed Manual (Aprox. 160k miles)
I get on average a combined of 10.5-11 mpg. This is an improvement of about a 1-1.5 mpg from when I first got the truck. (Downhill on the interstate I get around 14mpg) One of the things I did to increase mileage was simply changing my tires to a "lighter ply". Even after going up a size in diameter, it increased my milage.
Old Jul 30, 2023 | 11:57 AM
  #298
Mika7536's Avatar
Mika7536
Nice, and good to know about tire size!
When I made my original post, I had passenger car tires on the truck. A long wheel base truck which usually runs without anything in the bed tends to slip on the gravel driveways I encounter, mine included.
I have since replaced those tires, when they wore out, with a set slightly more aggressive. My milage now is roughly 15.3, 13, 14.4, 17.2, 13.6, 15.2, 12.4, 12.9.
Old Sep 23, 2024 | 08:25 AM
  #299
Auslander's Avatar
Auslander
1984 D150 shortbox, 2nd owner, bought from estate with 92k
225 /6 4spd... Lean Burn removed, electronic ignition w/ distributor, 1 bbl carb installed, de-smogged, air pump removed, 3.55 gearing, A833 o/d, 255/75/15, no catalytic, getting 21mpg hwy, 16 city
Old Apr 1, 2025 | 11:45 AM
  #300
Ihave_A_dodge's Avatar
Ihave_A_dodge
6-8 all the time. whether im towing or not. 360LA
