D100 or D150?
Old Oct 16, 2009 | 06:56 AM
red_motofox's Avatar
red_motofox
Default D100 or D150?
How do I tell if the truck I bought is a 100 or a 150?
Is there any real difference?
Old Oct 16, 2009 | 08:29 AM
charlie1935's Avatar
charlie1935
Both are 1/2 ton.
I believe the 150 has a higher load rating due slightly heavier duty suspension.
If I remember correctly it was introduced as a heavy 1/2 ton.
Old Oct 16, 2009 | 09:02 AM
Mad Mudder's Avatar
Mad Mudder
Originally Posted by charlie1935
Both are 1/2 ton.
I did not know that they had a D150. Iknow they have a W150, which is a 4x4.
Old Oct 16, 2009 | 10:24 AM
charlie1935
Any W is 4x4, be it 100, 150, 250, 350 or whatever.
All 4x2 were D series.
Old Oct 16, 2009 | 11:43 AM
aaron7's Avatar
aaron7
D100/150 2wd
W-series 4wd
EDIT: Had it wrong!
Old Oct 16, 2009 | 11:44 AM
red_motofox
Both are 1/2 ton.
What about transmission and gearing. Wouldn't a higher load rated truck need a heavier power-train?
Old Oct 16, 2009 | 11:54 AM
tooltime's Avatar
tooltime
All d trucks are 2wd and w trucks are 4wd. If a auto it is a 727 and a stick i think is a 904 trans not sure on the gearing
Old Oct 16, 2009 | 02:22 PM
charlie1935
The 904 is automatic, not as heavy duty as the 727.
Old Oct 16, 2009 | 07:43 PM
racer9's Avatar
racer9
My "D" has overload springs on the rear. Also the "150" on the fender. I believe that's the only difference.
Slant6, A833OD trans.
Old Oct 16, 2009 | 08:45 PM
AeSix's Avatar
AeSix
pre-1981 it's a D-100, 1981 and newer are D-150, 1994 and newer are 1500.
(I think it was 1981)
Other than that, from what *I* have seen, they are pretty much the same truck. Pretty much just updating it with the times, like they did in 94 for the 1500 tag.
