82' D150 lift
Old Oct 29, 2009 | 07:43 AM
aydena's Avatar
aydena
Default 82' D150 lift
Im looking for some information on how to lift my 1982 Dodge ram D150 Custom, It has leafs on the back and coils on the front ?
THanks
Old Oct 29, 2009 | 07:49 AM
Mad Mudder's Avatar
Mad Mudder
THanks
I dont think there is any lift systems out there for 2 wheel drives.
Old Oct 29, 2009 | 07:57 AM
HeliDeiter's Avatar
HeliDeiter
Preformance Accessories makes a 2'' Body Lift.
Old Oct 29, 2009 | 08:20 AM
aaron7's Avatar
aaron7
Wouldn't the 4x4 body lift fit? I don't see why that would be any different.
As for the suspension lift, you'd just need shackles and taller springs to get a 2" or so suspension lift. Any higher than that and you'd need more parts to fix the steering and suspension geometry.
Old Oct 29, 2009 | 11:04 AM
aydena's Avatar
aydena
I was thinking that that myself, surely i can just fit 2" bigger blocks on the rear axle with bigger U-bolts and fit Spacers between the springs on the front ?
Old Oct 29, 2009 | 11:10 AM
aaron7's Avatar
aaron7
Yah. I had spacers on my Cherokee coil springs. Don't go above 2" and you're ok.
Old Oct 30, 2009 | 09:13 AM
aydena's Avatar
aydena
Any ideas on what is required to do a body lift ?
And what is generally the best in terms of height to lift the body by ?
Thanks
Old Nov 15, 2009 | 10:19 AM
82w150's Avatar
82w150
you will need a longer shift linkage, depending on how high you go tcase linkage throttle relocating a few brake lines that kind of stuff
