85 ram - rewiring project, need some advice
Old Nov 2, 2009 | 03:38 PM
Highway's Avatar
Highway
Question 85 ram - rewiring project, need some advice
I relocated my battery box to the rear of the truck. I installed a ford type solenoid in the battery box to shut off power to the entire truck via toggle switch; as a security measure. Will I still need a starter relay? Can I wire the "starter" switch straight to the starter or will I need a relay for that?
Old Nov 2, 2009 | 04:29 PM
crazzywolfie's Avatar
crazzywolfie
you could wire the starter to a switch. it is the single brown wire on the starter relay. hit with some power and it will turn your engine over.
