1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
palm sanders will remove paint unevenly and you will really see it if you use black primer. sanding block is what you should use if you want the body to not look funny.
