w150 lift?
Old Mar 8, 2010 | 11:05 PM
  #21
cbg32's Avatar
cbg32
Go with a tuff country 4in ez-lift with front springs and rear blocks. That will clear 35s with little rubbing. If you go with their 6in kit, its alot more expensive and then you have to worry about steering parts and if needed a drop transfer case kit. but its up to you. I have two old school dodges. A cummins with a 8in lift on 37s and a w150 4in lift with 35s. both are awsome except the 8in lift was about $1500 with all the right parts. The 4in done right with tuff country lift, 4in drop pitman arm, steering stabilizers, and bilstein 5100 shocks was $900. you could get away with just the lift kit.
Old Sep 6, 2020 | 11:51 AM
  #22
Ryan Whitehead's Avatar
Ryan Whitehead
Default W150 lift kit
Hey I'm looking at lifting my 84 w150 4" I found a rough country lift kit with all 4 leafs shocks and blocks will I need anything esle?
Old Sep 6, 2020 | 12:04 PM
  #23
Link to the kit? If you get 4 springs, why do they need blocks?
Old Sep 6, 2020 | 02:04 PM
  #24
Ryan Whitehead
Default Lift kit
Wont let me send the link
Old Sep 6, 2020 | 04:28 PM
  #25
Hmm.... wasn't aware we had on restrictions on posting links..... The spammers don't seem to have any trouble with it..... Can you post it as just plain text?
Old Sep 6, 2020 | 05:02 PM
  #26
Ryan Whitehead
Old Sep 6, 2020 | 07:59 PM
  #27
Looks pretty complete. According to the description (I looked it up on their site) the rear springs replace your blocks, which is a good plan. Should be everything you need there.
Old Sep 7, 2020 | 11:02 AM
  #28
Ryan Whitehead
Default Lift kit
Thank u and would u be worried u joints binding should I re angle the rear end?
Old Sep 7, 2020 | 01:09 PM
  #29
You are only going up four inches, and the driveshaft is pretty long...... I would think the kit will come with shims, to correct the driveshaft angle at the diff..... Should be fine.
Old Sep 7, 2020 | 06:42 PM
  #30
Ryan Whitehead
Default Lift kit
Thanks man
