w150 lift?
Old Nov 11, 2009 | 02:51 PM
82w150's Avatar
82w150
Question w150 lift?
Hey guys im a new dodge owner and im looking for a good lift for my truck i know with alot of vehicles you can use other oem parts to lift vehicles, that being said who knows the best way to get 4-6 inches of lift?
thank you all!
hope to talk to you all soon
Old Nov 12, 2009 | 06:54 AM
Ironmower's Avatar
Ironmower
Are you lookin for the best lift "kit"? or are you lookin for the best way to do it cheap? suspenision or body?
Old Nov 12, 2009 | 09:38 AM
82w150's Avatar
82w150
no body lift just suspension and if the best way to lift is cheap than that way depends on what you have for ideas really
Old Nov 15, 2009 | 06:50 PM
aaron7's Avatar
aaron7
4" lift for $500 http://www.autopartswarehouse.com/de...85c7ab9e&gan=1
Pair that with a 2" body lift and BAM there you go.
Old Nov 16, 2009 | 09:15 AM
82w150's Avatar
82w150
I dont do body lifts raises center of gravity there for reducing performance not my style sorry.
Old Nov 16, 2009 | 04:14 PM
SEAL's Avatar
SEAL
A body lift doesn't raise the center of gravity as much as a suspension lift does.
Old Nov 16, 2009 | 06:15 PM
crazzywolfie's Avatar
crazzywolfie
he is mixing up center of gravity and top heavy.
Old Nov 16, 2009 | 09:44 PM
82w150's Avatar
82w150
yeah you guys obviously dont understand geometry putting the body further up on the fran makes the vehicle top heavy witch means the center of gravityis changed if it were an s10 it would be different beacuse the body is so light, I am looking for an economical and intellagent way to lift the vehicle someone just tell me what springs from what year vehicle i can install or i just go buy a kit if you dont have that information done comment!!!!!! period end!
thank you to those who actually had real information and eff off for those who dont!
Old Nov 17, 2009 | 07:40 AM
SEAL's Avatar
SEAL
82w150
No need to get nasty, I believe aaron7 answered your original question and we had all moved on to another topic (that being center of gravity) that you raised by your third post on this thread.
That being said I wonder how I got an Engineering degree without understanding Geometry and Physics?
Here is some real information so I don't have to (eff off). Remember that a suspension lift raises everything on the vehicle but the axles. When you raise the mass of the vehicle, be it the mass of everything but the axles or just the the mass of the body, you raise the center of gravity. Since everything but the axles has more mass than just the body any amount of lift on the suspension has a greater effect on the center of gravity than the same amount of lift on the body alone. When the center of gravity goes beyond a certain point the vehicle becomes top heavy and can even become unstable.
Old Nov 17, 2009 | 08:40 PM
82w150's Avatar
82w150
i believe i said i dont want any information unless its what is stated above!
and where anywhere did I say that a suspension lift doesnt raise the ceenter of gravity? I disregaurded that statement beacuse i know and I dont want it any higher than my suspension Is not onlly designed to be but the way it preforms body lift is to cheat and fit a bigger tire it gives no ground clearance so unless you can tell me what i stated above (eff off)
