1990 dodge w250 hub problem
Old Nov 18, 2009 | 02:37 PM
mhetrick89's Avatar
mhetrick89
Default 1990 dodge w250 hub problem
Im in the process of redoing my entire brake system on my 1990 dodge w250. its the 5.9 360 gas. Well im at the part where im starting to put the hub back together. i have already repacked the new races and bearings and all that but I have one problem. I for got how to put the hub back to gether. can anyone help. So far this is what ive done. New: master cylinder, brakebooster, inner and outer rubber brake lines, rotors, bearings, races, seals, porporting valve, and deleted abs.
Old Nov 18, 2009 | 03:11 PM
SEAL's Avatar
SEAL
What kind of hub do you have manual or automatic? I have to say you have guts taking the hubs apart without a manual. Did you take apart both sides at the same time? If not you can do the other side and be careful as you lay the parts out in order and keep the out side facing up.
Old Nov 18, 2009 | 03:28 PM
mhetrick89's Avatar
mhetrick89
Well ive done this before but ona differnt hub type. its auto locking hubs. i belive its a free floating axle. and without a manual i know thats my problem. I cant find one anywhere
Old Nov 18, 2009 | 03:38 PM
SEAL's Avatar
SEAL
I can try to talk you through it assuming I have the picture of the same auto hub you have. Do you have a hub sleeve (that is a tube with grooves along its length and a C ring about 1/3 of the way down)? How many parts are there to the hub?
Old Nov 18, 2009 | 04:50 PM
mhetrick89's Avatar
mhetrick89
That is the right picture you looking at. Where did you find it. I've searched for at least 3 hours looking for it. I'm not sure how many parts there are. I'm at work right now.
Old Nov 18, 2009 | 05:33 PM
SEAL's Avatar
SEAL
It is in my Chiltons manual #8166. The title is Dodge/Plymouth trucks 1989-1991 Repair Manual.
Old Nov 18, 2009 | 05:45 PM
mhetrick89's Avatar
mhetrick89
Can u walk me through it
Old Nov 19, 2009 | 06:32 AM
SEAL's Avatar
SEAL
I am willing to try. We need to set a time when we can both be on the forum at the same time or via telephone to do this. There are a lot of parts in this procedure that we are going to have to identify both pictorially for me since I don't have the actual part and verbally for you since you don't have a picture or the part names. For lubrication you need Dexron ATF and Mopar 4293040 lubricant or equivalent. ( the book says if you use the wrong lubricant the hub WILL fail )
Look here what I just found.
http://ww2.justanswer.com/uploads/as...551_ANSWER.pdf
