Best replacement shocks for 2wd daily driver?
Old Dec 17, 2009 | 09:46 AM
aaron7's Avatar
aaron7
Default Best replacement shocks for 2wd daily driver?
1984 D250 camper special
I currently have some rusty things up front and some weird coilover things in the rear.
Truck will never be used to tow or be loaded up with anything more than a garden tractor.
It's my daily driver.
What are the best shocks to put in it?
Old Dec 17, 2009 | 09:29 PM
AeSix's Avatar
AeSix
Discount Auto's shocks on special
That's what I plan to put in mine when I get some $$ up.
I hate being a broke 4$$
Old Dec 18, 2009 | 08:55 AM
aaron7's Avatar
aaron7
I was leaning towards Rancho shocks. Anyone run them?
Old Dec 18, 2009 | 10:37 AM
dreamer1uk's Avatar
dreamer1uk
Hi,
I have never used the Rancho shocks, but i would stay away from the cheaper Gabriel and Monroe shocks, and i have heard alot of negative feed back with those shocks.
A good brand is and which i have personally used in the KYB's.
Hope this helps.
Old Dec 18, 2009 | 12:29 PM
aaron7's Avatar
aaron7
Yah I heard those $20 Monroe auto parts stores ones were junk.
KYB Gas-a-just I would imagine is what you're talking about correct?
Old Dec 18, 2009 | 02:03 PM
SEAL's Avatar
SEAL
Since the factory shocks were replaced my truck has had Monroes on it its whole life with good results but I don't buy cheap ones. You get what you pay for.
Old Dec 18, 2009 | 02:05 PM
aaron7's Avatar
aaron7
When I go to order 84 D250 shocks they ask if I have the HD or not.
I have no idea! It's the camper special and has those coilover things in the back, does that make it the HD?
Old Dec 18, 2009 | 02:26 PM
SEAL's Avatar
SEAL
I live a long way from the parts store so I need to make sure I have the right parts when I get home. I would think they are both the same except for piston and/or shaft diameter and the HDs might have the helper springs. Have the parts guy pull both so you can see them. If you can't tell by sight which are correct I would buy them both and compare them to what you remove from the truck. Then return the wrong ones for a refund. Do not cut the plastic keeper straps on the wrong ones or they won't take them back.
Old Dec 18, 2009 | 02:37 PM
AeSix's Avatar
AeSix
I Would take a guess that you do have a heavy duty setup, being for a camper and all... but SEAL is right, either look at em at the store and if there is an obvious differance, buy what looks right, and if not, buy a set of HD, and 1 regular take em home and compare...
Old Dec 18, 2009 | 03:59 PM
aaron7's Avatar
aaron7
Hmm... the stores around here don't have KYB. I can get a set of 4 KYB GR2 from ebay for $100 shipped.
Wonder if I can measure to find the difference or something.
