looking to buy...help me out!
Old Dec 18, 2009 | 10:39 PM
thabble's Avatar
thabble
Thumbs down looking to buy...help me out!
i'm possibly looking at an 87 Dodge ram with a slant 6...it is leaking a little fluid, but has a good interior and body...i've never really liked dodge till here recently and have really been getting into these 1st gen rams for some reason...what are the things i should check and look for...you know the normal things that usually need fixing? thanks for any help you can provide!
Old Dec 19, 2009 | 06:18 AM
rwb's Avatar
rwb
The slant 6 is pretty much an indestructable engine. Just make sure that you check the compression on the engine and that you check the tranny. Don't expect the ac to work and be prepared to change the carb. I had to do all of that on my old 82 d150 I bought in 92. I kept it until 02 and its still running today.
Old Dec 19, 2009 | 12:52 PM
tooltime's Avatar
tooltime
Rust problems is above the rear wheel wells especially if have molding and the cab corners. Check out the frame. Most of the trucks are missing jacks,manuals and sometimes the spare tires. If you can pull up the carpet/mat and check the floor. Check the fluids. Check out a place called cliffards 6=8 they are for slant 6 with v-8 power place. Also make sure the climate control works(mine the connector had rotted off) and the wipers. If get it may want to take off the cowl and loosen the bottom if front fenders to clean out any dirt,leaves etc.Good luck
Old Dec 21, 2009 | 01:31 PM
RamKing's Avatar
RamKing
i have a slant six great truck leaks abit but its a good truck
Old Jan 3, 2010 | 04:35 AM
79powerwagonneb's Avatar
79powerwagonneb
If your looking for parts for a 70's dodge....i have almost anything you would need! I started a project with a 79 powerwagon and i relocating to houston. With that being said i have no room for the powerwagon. Extra parts include long bed( ready sand blasted and primered)..cab..(painted sublime green)...doors, fenders, inner fender wells, radiator support( sandblasted and primered)..2wd rolling frame with 8 3/4 rearend...new headman headers...so much stuff i cant even list! Plus...i have a complete powerwagon ready to drive....with 318..727..i pretty great shape...interior looks almost new...just needs new carpet...and has a lil tear in the seat...it is a complete powerwagon!!! so if anyone is intrested...contact me! thanx!
