seats ??
hey all,i just put a set of ramcharger buckets and console in my 93 d150.
the pass side one is a fixed seat,i removed the hinge and hardware for it. does anyone know if i could take a driver side seat track that is adjustable and attach it to pass seat to make it adjust forward and backward. thankyou for any help
should be able to, but might need some modifications (bending, probably not cutting, and possibly some drilling)... but keep in mind if the controls/levers are on the side, you'll either need room between the seat and console, or have it upside down, which probably won't work too well...
If you have one on the driver's seat now, and it's same as the one you'd be using on the passenger seat, just take some look-sees about the bolt holes, levers, and any clearences you'd need for proper operations.
crazzywolfie
You have obviously put a lot of time in at the welder and are taking something for granted. ( SKILL ) I have seen people with a welder and time really screw things up.LOL
hey aaron7, if you use buckets from ramcharger 2 of the 4 holes to mount them are already there,seat belts are another story,i am going to make brackets on the side of the console to hold them in position.
the 91-93 ramcharger seats are way comfortable look good too. good luck..
Trending Topics
Isn't that the truth! I have heard it said that some people shouldn’t own guns……..I say some shouldn’t own a welder!
But practice develops skill. I am not as good with a welder as I once was. I welded for a year professionally and was pretty darn good at the time. I can still weld as good left handed as right but amperage settings are not as automatic as they once were.
