Need help about engine 6 inline
Old Mar 26, 2010 | 05:15 AM
galih's Avatar
galih
Originally Posted by SEAL
If you know the used bearing sizes I assume the crankshaft is out of the engine. Is this right? If it is give me the 7 digit casting number from the crankshaft and I can get all the information you need that will include wether it is cast or forged. The casting number will also give you the exact year it was produced.
Finally I can continue the project.. as you said.. it takes very long time to get the parts..
This Slant has STD bore so I just replace with new rings but 30thou for Rod bearing and 20thou for Main bearings of under size..
And now, I still waiting the Felpro gasket set to starting rebuilt it
Thank you my friend
Old Mar 26, 2010 | 05:16 AM
galih's Avatar
galih
Originally Posted by RamKing
Check out www.slantsix.org very usefull
help me out alot
Yes absolutely right, it was very helpfull
Thank you for kindness information
Old Mar 26, 2010 | 05:19 AM
galih's Avatar
galih
Originally Posted by ddarnell
Slantsix.org is THE place. Spent alot of time there in years past. Nice truck BTW
David
Yes, I use it for my reference..
