88 ram 50 guzzling gas
I'm not sure why my truck is drinkin so much gas. Just bought it last Sunday. I filled him up on Tuesday and it's Thursday now, and I'm almost down to a half tank. I made a few stops besidesjust to work and back which is like 3 miles away from my house. What do u guys think is going on? And what can I do to get awesome mpg or improve my mpg? Fuel filter? Carb cleaner? I don't know what to do need some help please. Thank you
If you want awesome gas milage buy a hybrid. Our trucks don't get great mileage but you should get better than 2-3 MPG. You may have a leak someplace. It is pretty hard to believe the engine used that much fuel without showing some other signs of problems.
Well I want to use this truck as my daily driver, and i want to use it to carry my dirtbike and other things if needed as well. The truck doesnt have the greatest idle, but im going to replace the fuel filter, spark wires, distributor cap and rotor, and it needs a new power steering belt. Will this help my mas mileage? I know this truck is somehow consuming more gas than it should.
like SEAL said you probably have a leaking fuel line somewhere if you are getting 2-3mpg. new spark plugs, cap and rotor might help a bit but if you have a leaking fuel line your fuel milage will not go up. your truck is 22 years old. those fuel line are probaly original. there is probably a few spots that are rust through. this could also cause your truck to not run right.
The hybrid remark was a joke. Nothing personal. You simply can't pour that much fuel into an engine that fast and have it run. A leak or a bad fuel gauge are about the only answers. A fuel filter would restrict fuel flow not give more. Same for a dirty carb or injectors.
hybrid vehicles are a joke. we should have mention that the fuel line is leaking is most likely in the frame rail behind the gas tank. all vehicles tend to have this same problem over time. you should be very careful if you do replace it. the brake lines will probably also be very fragile behind the gas tank if they have never been replaced.
Trending Topics
Is there a link or a page on the forum that will tell me and or show me how to replace my fuel lines and fuel filter. If there is a leak can I patch it or does it have to be replaced?? Sorry still learning about cars and trucks. But I am willing to learn and listen
