swaping a 360 for a 440
Old Feb 8, 2010 | 01:36 PM
lets_baja's Avatar
lets_baja
Default swaping a 360 for a 440
i have an 1993 dodge d250 and i was woundering how difficult it is to swap my 360 to the 440 and if it bolts right up or do i have to do any major mods.... thanks for all the help
Old Feb 8, 2010 | 03:25 PM
aaron7's Avatar
aaron7
This question has been asked many, many times.
Mounts are totally different. You'll need a new tranny too. Possibly driveshaft.
http://www.bouchillonperformance.com/BPEtruckKit.asp
You'll probably need many other parts too.
Old Feb 18, 2010 | 02:58 PM
MOPARPAT's Avatar
MOPARPAT
Being it'a a 250, you have alot of room to work with. You will need a big block tranny and poss drive shaft change. Change the mounts, they have kits to do this with, check local speed shops or even ebay. The power difference will be noticed. You might want to use bigger tortion bars too cause of the extra weight.
Old Feb 18, 2010 | 03:18 PM
aaron7's Avatar
aaron7
Cool, so you pretty much quoted my post lol
Old Feb 18, 2010 | 03:23 PM
MOPARPAT's Avatar
MOPARPAT
yep also added a couple more ideas
Old Feb 19, 2010 | 12:29 AM
440ram's Avatar
440ram
there is an adapter from patc that adapts small block tranny to big block tranny, also 440source .com has the mounts and many other parts on their site cheap. its not hard, get the adaptor plate and you will keep your current driveline.
Old Mar 5, 2010 | 04:42 AM
bigbraunboy's Avatar
bigbraunboy
dont forget ur accessory mounts lolol
