Location jack in the chassis
Yes,jacking under the center section can loosen the axle tubes,I have seen this,tho not common,often the result is premature tire and bearing wear.
Gearing is a good place to start,depending on primary use,3.91 gears are a good balance.
You can jack under the outer axle tube or spring plate,under the control arm(depending on clearance) or k member or under a flat part of your frame.
