play in steering
Old Feb 13, 2010 | 01:12 AM
schulteff's Avatar
schulteff
Default play in steering
theres a lot of play in the steering of my 90. can i take care of that by taking off the bolt on top of the steering box and tightening down the screw?? any help is much appreciated! thank you!!
Old Feb 13, 2010 | 07:57 AM
SEAL's Avatar
SEAL
Further inspection is necessary as we do not have enough information to diagnose your problem. You haven't told us wether you have a W or D so some of these things may not apply but here is a starting point. Have someone move the steering wheel back and forth slowly while you are under the truck to find out where the play is. Rag joint, steering box guts, loose blots that hold the steering box, rusted out frame, ball joints, idler arm, drag link, center link and tie rod ends are all suspects.
Old Feb 13, 2010 | 08:45 AM
97Dodge's Avatar
97Dodge
Yes you want to check everything before you adjust the screw. Make sure everything is good. If everything does check. If you have to adjust it no more than 1/4 turns at a time.
Old Feb 13, 2010 | 10:05 AM
dhvaughan's Avatar
dhvaughan
yes.
as you tighten up that inner bolt you should feel a decrease in the play.
don't go too far, or you'll find that the steering won't automatically recenter as you come out of a 90* turn. try to find that sweet spot with minimum play that will still recenter.
Old Feb 13, 2010 | 10:06 PM
schulteff's Avatar
schulteff
how do i figure out which model i have? all i know is its a 90 power ram, single cab, with a solid front axle (new to dodge's don't know if they all had that). thank you for all the help, its much appreciated!! i'll start checking everything out.
Old Feb 13, 2010 | 10:47 PM
crazzywolfie's Avatar
crazzywolfie
a power ram is pretty much a short box w150.
Old Feb 14, 2010 | 03:38 AM
schulteff's Avatar
schulteff
Default confused
i'm confused now because it has a long box on it.
Old Feb 14, 2010 | 05:09 AM
SEAL's Avatar
SEAL
W150 is 4x4 and D150 is 2x4. Long or short bed doesn't matter in this case. The 150 designates a half ton.
Old Feb 14, 2010 | 04:08 PM
schulteff's Avatar
schulteff
Default w or d
okay thank you!! now i know what i have. my truck is 4x4. thank you!!
