Spark issues on my power ram
My 86' dodge w150 (power ram) w/ 360 4 barrell wont start. I Have pulled the spark plug and set it on the block and tried starting, no spark. Next step i took the main plug going from the ignition coil to the top of the distributor i put that to the block and tried cranking no spark untill i stopped cranking and a quick spark happened as i was turning the key away from the cranking position.
All plugs and wires are in the right places and on tight
I have brand new plugs and wires(plugs are gapped to spec), ignition switch, ignition coil, distributor cap, distributor cap rotor button.
Next step tomorrow would be the ignition module.
Any other ideas would be great, i have done what i know and hasnt worked for me
