Need Help With E Brake Cable 89 w150
Old Feb 21, 2010 | 07:39 PM
itsrname2's Avatar
itsrname2
Default Need Help With E Brake Cable 89 w150
I replaced the rear left and right cables because one was broke, But when I now try to connect them to the Equalizer that is under the driver side door, they dont seem to match up well. It seems the right brake cable is about 1 to 2 inches shorter on the end then the Left side. I know the Equalizer is there to ajust for that but it seems too much.
Could anyone let me know if they had this issue and/or send me some pictures of the rear cables connecting to the Equalizer so I can what the offset is to see if this is normal.
Thank you.
Old Feb 23, 2010 | 09:27 AM
itsrname2's Avatar
itsrname2
anyone??
Old Feb 23, 2010 | 12:35 PM
SEAL's Avatar
SEAL
Both of mine are the same length from the bracket that holds the cable sheath to the ends of the cable at the equalizer.
Old Feb 25, 2010 | 12:19 PM
itsrname2's Avatar
itsrname2
thank you Seal, have you ever replaced yours? or are yours still factory mopar ones?
Old Feb 25, 2010 | 12:41 PM
SEAL's Avatar
SEAL
Factory.
