P.o.s
Old Feb 28, 2010 | 09:03 PM
audioman10's Avatar
audioman10
Default P.o.s
okay does a 92 le ram 150 have a possie....
Old Mar 1, 2010 | 12:17 AM
crazzywolfie's Avatar
crazzywolfie
the best way to find out is take your vin # to the dealership and you them to print you out a build sheet.
Old Mar 1, 2010 | 05:33 AM
SEAL's Avatar
SEAL
Jack both wheels off the ground. Turn 1 wheel by hand and note which way the other wheel turns. If they are both turning in the same direction you have possie, if they turn in opposite directions no possie.
Old Mar 1, 2010 | 08:49 AM
aaron7's Avatar
aaron7
Yah, just go to any Chrysler dealer with your VIN. They'll tell you all the original specs.
Old Mar 1, 2010 | 12:37 PM
SEAL's Avatar
SEAL
There is one flaw with judging anything on the vehicle, especially possie via what is on the build sheet. Unless you are the original owner you can't be sure the differential is original equipment. In this case if it had been changed to possie and you put in the wrong fluid you would destroy the differential. We must remember that we are dealing with old vehicles that a lot of people like to modify. This is why the build sheet is a good starting point but you must verify the information unless you are sure that the part is original to that vehicle.
