Installed choke thermostat..it runs rich and dies
Old Mar 21, 2010 | 06:05 PM
chris015's Avatar
chris015
Default Installed choke thermostat..it runs rich and dies
Alrighty,so i got my truck a few months ago. And ive been running it without a choke therm. Well today i installed one and When i accelerate between 25-50 mph it surges,bogs and dies. and floods out. The carb has been fully rebuilt with a new choke pulloff. Once i unhooked it the truck drove fine again.What gives?
Here is some things i noticed.
The choke idle screw sits on the smallest notch on the plastic choke piece,even if i hit the gas,it still rides the smallest bump. if i back it off any more it wouldnt work correctly.
Also when fully warmed the butterfly is slanted by say 20% degree's.
oh yea..its a 1978 d150 with the 2bbl carter 318.
Old Mar 22, 2010 | 09:22 PM
chris015's Avatar
chris015
Well i feel stupid,(im still new at this carb stuff,i grew up in the fuel injection age) Evidently theirs suppose to be a hose that runs to the choke thermostat to heat the coil....I don't have that...IF you can get me a pic of it or where i can buy what i need i would greatly appreciate it. And where is it running too? the crossover? wheres the fitting etc that it runs to exactly
Old Mar 22, 2010 | 10:04 PM
dhvaughan's Avatar
dhvaughan
i'm not familiar with the dodge but on my old chevy a steel tube came off the intake manifold to the choke t-stat spring.
if you don't get it figured out, just install a manual cable to pull the choke on/off. its actually a hell of a lot easier to get to work. just understand how the choke linkage at the carb works. usually there's 2 motions going on - the butterfly flap, and the high idle steps. those motions might be tied together with a rod. and/or a vacuum pull off might be involved.
