90 d250 suspension issue
Old Mar 23, 2010 | 09:40 PM
madmatthew88's Avatar
madmatthew88
Exclamation 90 d250 suspension issue
im having trouble with the right side front if im cruising and hit a bump my front right side tire starts shaking very bad feels like it might come off but i tap the brakes and it stops. can anyone help me with what ever they think the problem could be. i just fied the sway bar up front but didnt help. thanks for any input
Old Mar 24, 2010 | 01:29 AM
crazzywolfie's Avatar
crazzywolfie
have you checked the nut/bearing's on the front tires?
Old Mar 24, 2010 | 05:39 AM
SEAL's Avatar
SEAL
Could be wheel bearings, ball joints, control arm bushings, or tie rods. Jack the tire off the ground and grab it top and bottom and check for movement. Do the same, side to side on the tire. Now grab a pry bar and lever the bottom of the tire up and down. These are not fragile parts so use some force. There should be no movement but from what you said there will be.
Old Mar 24, 2010 | 03:48 PM
madmatthew88
Thumbs up thank you
thanks for the input it helps alot guys
