Flywheel and pressure plate???
Hi, I am changing my 1987 dodge d150 ram from automatic to a manual. I have a A833 trans with the overdrive. The guy gave me a flywheel and pressure plate with it. It was the wrong flywheel, doesn't fit on crank. So I need to know if the pressure plate is right. The inside disc measures exactly 10.5", the boltholes are 6' apart and bolthole one end to the other is 11.5" is this a mopar pressure plate does it matter??? If it will work, what size flywheel do I need??
Thanks
Thanks
