rear end oil?
Old Apr 3, 2010 | 02:13 PM
shortwide84's Avatar
shortwide84
Default rear end oil?
housing seal is bad so i'll be replacing that soon.. what oil do i use? 80-90?
Old Apr 3, 2010 | 08:09 PM
shortwide84
changed it today and it isn't leaking from the seal, it's leaking where the drive shaft enters the rear end. what is the problem and how hard is it to fix?
Old Apr 7, 2010 | 09:24 PM
440ram's Avatar
440ram
Its easy to fix. You will need a new seal, and new crush sleeve. set pinion pre-load and your done.
Also I would use the thicker 140 oil if you have a stock rearend.
Old Apr 8, 2010 | 05:54 AM
SEAL's Avatar
SEAL
If the rear is posi you will need a friction modifier added to that oil. If you are going to change the seal it is not hard like 440ram said but the pre-load must be set correctly by the book within 5 ft-lbs or you can destroy the rear.
Old Apr 8, 2010 | 05:52 PM
shortwide84
do you know where i can read about it more in depth?
