Tire Pressures
Old Apr 20, 2010 | 10:06 AM
muse's Avatar
muse
Default Tire Pressures
I have a 1984 D100, running 235/75 R15 tires on the stock rims. the tires are all the same type (Goodyear Wranglers), yet they disagree with what the reccommended inflation pressure. I asked a mechanic, and he told me to look in the operator's manual. Well, 26 years is a good long time for that manual to get lost, as mine has. does anyone know the right pressures, or have an operator's manual for this truck?
thanks.
Old Apr 20, 2010 | 01:25 PM
RSDodgelover's Avatar
RSDodgelover
No owners manual here, just some experience. Depending on what ply rating the tires are and how you heavily you load the truck the starting pressure should be between 32 and 35 lbs. These are starting pressures and you will need to adjust to your needs.
Old Apr 20, 2010 | 03:29 PM
aaron7's Avatar
aaron7
I never understood how you figured out the proper tire pressure when you have non-stock sized tires.
The pressure ratings in the manual/door jam are for stock sized tires.
The pressure rating on the side of the tires is the max pressure when cold.
How the heck do you figure out what you should have? Just spray paint a line on the tire and see how it wears? lol
Old Apr 20, 2010 | 04:33 PM
crazzywolfie's Avatar
crazzywolfie
i try to keep mine at 32 psi. of course if you are towing or halling a load you may want increase the mount of air in you tires.
Old Apr 20, 2010 | 05:02 PM
aaron7's Avatar
aaron7
My tires say 60PSI max cold so I've been running them at 40. They look like they are wearing evenly.
They are 6ply 16.5x9.5 box truck tires haha
Old Apr 22, 2010 | 02:15 PM
charlie1935's Avatar
charlie1935
Chalk will do fine and is quicker than paint. Just roll it back and forth and look at the chalk pattern. Afjust pressure and rechalk, roll back and forth again until chalk pattern is even across tire tread.
Old Apr 22, 2010 | 02:19 PM
aaron7's Avatar
aaron7
Guess that makes sense, I'll try it!
Old Apr 23, 2010 | 10:28 AM
muse's Avatar
muse
yeah, hey... I knew about that trick for race tires, but just never associated it to street tires... thanks, I'mma try that.
Still, if anyone can fill me in on the factory reccommendations, I'm purely curious now.
