LA Parts to Mag Block? Magnum Heads to La Block?
Old Apr 27, 2010 | 07:11 PM
js1023's Avatar
js1023
Default LA Parts to Mag Block? Magnum Heads to La Block?
Hello
Ok, So I have everything needed to build a mopar 360 LA series. Well today I picked up my motor from the machine shop and I was told that motor was no good. The block was salvagable, but needs 1700$ worth of work. And the heads are cracked.
I was wondering if I got a magnum block from a 1998 jeep or dodge durango or ram a 318 or 360 are interchange some parts. Because, I have following comp cam
http://cgi.ebay.com/ebaymotors/ws/eB...d=300417417992
Can use the cam in a mag block?????? Also are the cam bearings and all the same or different?
I know the heads are completely different. But can I use the Crosswind #55025 with a Carb??
Or another senario could be I can salavage the block and bore it out, and bolt on some mag heads??
What would be the best course of action...with the least amount of money...
So I can get the ol dodge back on the road...This motor is going in an old dodge d100.
