Need a new window regulator 93 dodge ram
Old Jul 12, 2010 | 01:16 PM
lexxerd's Avatar
lexxerd
Default Need a new window regulator 93 dodge ram
I have been searching around online and Ive been having trouble finding a window regulator for the driver side window that specifically states it fits the model of my truck. I have a 93 D150 RAM ATX.
Will this work http://www.autopartswarehouse.com/de...1&apwidLfbPNjH ?
Problem with the window is it wont even stay up anymore, the window track is shot.
Old Jul 12, 2010 | 02:05 PM
SEAL's Avatar
SEAL
I don't know if that will work or not but I doubt it. If the track you are talking about is the one on the bottom of the window, you might try a replacement glass shop. All of the following vehicles use the regulator you are looking for or so I am told. You may have to go for used.
DODGE 250 PICKUP 91-93 man
DODGE 350 PICKUP 91-93 man
DODGE 150 PICKUP 91-93 man
RAMCHARGER 91-93 man
1993 DODGE RAM 150 PICKUP
Old Jul 12, 2010 | 02:57 PM
lexxerd's Avatar
lexxerd
Well Ive checked the local junk yard and there are no dodge trucks. when I took the door panel off the problem seemed to be the gear section similar to what can be seen in the link above. The gears don't touch each other anymore and they are rusty. If you turn the window crank it does nothing, its just completely loose.
