93 ram turn signals stopped working
Old Jul 22, 2010 | 12:40 PM
lexxerd's Avatar
lexxerd
Default 93 ram turn signals stopped working
On my 93 D150 ram the turn signals dont work at all. I noticed something was wrong when the day before my left and right turn signals would blink very fast, like indicating a bulb was out so I ignored it for a few days until I could check and see which one was out. Well now I get no lights and nothing from the gauge cluster. Any good places to start? I looked at the bulbs and none of them look bad but of course I'm not 100% sure.
Old Jul 22, 2010 | 10:34 PM
crazzywolfie's Avatar
crazzywolfie
sounds like the flasher relay is dead. they tend to speed up or slow down sometimes before they die. you can try swapping it with the flasher relay from the 4 ways
Old Jul 23, 2010 | 10:53 AM
lexxerd's Avatar
lexxerd
Where is this located at? I don't have a manual for this truck since its just a beater. Also are you saying there are similar relays I can swap in to see if that's the problem?
EDIT
Nevermind, found it on the main fuse panel under the steering wheel column, swapped the hazard relay in its place and it worked like a charm, thanks!
