Wheel fitment-chevy to dodge
Old Aug 20, 2010 | 08:37 AM
CSXfan's Avatar
CSXfan
Default Wheel fitment-chevy to dodge
Will 8 lug wheels off a 3/4ton chevy fit my '75 W200 8 lug? Thanks.
Old Aug 20, 2010 | 09:59 AM
gyman98's Avatar
gyman98
They will but you will likely need a spacer to clear the tire rod/draglink depending on the chev wheels you have. If your wheels are newer they will be setup for 9/16 lugs but your truck only has 1/2" so take your time installing so you get them on right
Old Aug 20, 2010 | 12:14 PM
CSXfan's Avatar
CSXfan
The wheels I'm looking for are just the old steel ones that came on older work trucks/vans. I know anything off an older Ford will work, but the only ones I can find are on Chevys.
Old Aug 20, 2010 | 12:26 PM
gyman98's Avatar
gyman98
About the only problem you may have then is the rubbing. A 1/8" spacer is usually all you need and can likely find them at a junk yard. Alternately you can buy 1,1.5 or 2" spacers for a more agressive look
Old Aug 22, 2010 | 09:53 PM
CSXfan's Avatar
CSXfan
Turns out the rear hubs are about 1/4" too big for the wheels. No biggy though, after a few minutes with an angle grinder I was good to go. Thanks for the replies.
