2nd gen seats
Old Aug 23, 2010 | 05:58 PM
shortwide84's Avatar
shortwide84
Default 2nd gen seats
will the 2nd gen bench with the folding arm rest fit in my 84?
Old Aug 24, 2010 | 12:32 PM
Hammar's Avatar
Hammar
I put a seat (split bench with the wide middle arm rest/storage container) from a 2000 Quad cab in my 1985 standard cab.
Width was good, right up against the doors. Height was OK, but I had to completely redo the brackets on the bottom to make it fit the cab. YOu loose a little depth, at 6'1" it's comfy, but I'd like anothe inch or two of leg room...
Good luck!
Hammar
Old Aug 25, 2010 | 04:41 PM
Sjelite's Avatar
Sjelite
Im looking for a direct swap also (or close too it) Hopefully some info will surface.
Old Aug 28, 2010 | 03:29 PM
shortwide84
Good luck!
Hammar
do you have pictures? what did you do with the brackets?
Old Aug 29, 2010 | 07:41 AM
aaron7's Avatar
aaron7
Only direct swaps will be 1st gen seats. Ramcharger buckets will fit in but I think you have to do a little drilling.
Old Sep 2, 2010 | 09:41 PM
shortwide84
i had a quad cab before this one and that is the style seats i'm looking to get in there. what kind of mods need to be done?
