1985 D50 Running Rough
Old Sep 25, 2010 | 08:16 PM
bgustafson's Avatar
bgustafson
Default 1985 D100 Running Rough (Need help with Plug Wire Diagram)
Just had some issues resolved with fusable links blowing, which caused it not to start. Before I resolved it, I replaced the Ignition Coil (I had clipped the coil wire to allow them to fit over the terminals, not sure that was a good idea), the Starter Relay and the Voltage Regulator. Prior to these issues, the truck had run fairly smooth. Now it is running pretty rough, I'm thinking some spark plug wires may have been misconfigured, in which case, I would need to know the proper configuration. I'd like to try to ensure that I have the wires plugged in right before I go into getting new wires and plugs, distributor cap, etc...
Old Sep 26, 2010 | 07:14 AM
SEAL's Avatar
SEAL
I assume you are asking for the firing order. It would be nice if you had mentioned what engine you have.
inline six = 1-5-3-6-2-4
V8 = 1-8-4-3-6-5-7-2
V6 = 1-6-5-4-3-2
Old Sep 27, 2010 | 07:17 AM
Ironmower's Avatar
Ironmower
If it's a D50 (mitsubishi?) That'll be a four. Wrong forum
Old Oct 2, 2010 | 06:17 PM
bgustafson's Avatar
bgustafson
Ok, this is an inline six.
I'm sorry, I don't understand how this translates to how the wires are connected to the distributor cap...
1-5-3-6-2-4
If I have the 6 plugs
x x x x x x
How does that tie to
00x00
0x00x
0x00x
00x00
i.e.
1
Old Oct 2, 2010 | 08:38 PM
SEAL's Avatar
SEAL
Trace the wire from #1 cylinder to the distributor cap. That is #1. Going clockwise around the cap #5 is next and then #3 and so on.
Old Oct 3, 2010 | 07:20 PM
bgustafson's Avatar
bgustafson
Ok, Seal, thanks, found it in the guide too. I had the truck to two different garages after the fusable link issue, (you responded to that too). Before the fusable link problem the truck didn't spit and sputter as bad as it was. Turns out plug wires were COMPLETELY hosed, I don't think there was one wire we on the right plug. A buddy of mine and I corrected all of them and it runs 90% better, timing may be off a hair, but it is not sputtering and backfiring. I'm thinking something happened at one of the garages, am hoping it was not intentional.
