Steering shaft
Ok so i just replaced my steering shaft with the borgeson. Well it all wen well accept that my tires were not perfectly straight with my wheel. So my wheel is about a quarter turn off when im driving straight. Can i just take my steering wheel off and turn it to fix it?
i did the same exact thing with my truck last month. i would also like to know what the fix is...i was going to pull my steering wheel, but ive had other projects on the truck that have been more important. it hasnt annoyed me yet since i havent been driving the truck at all... big trans leak, needs new exhaust, brake work. been busy doing all of that
I am not positive but if you set the wheels straight and then remove the spline end of the steering link at the gear box, turn the steering wheel straight and reinstall the link to the gearbox, it should fix the problem. I did this on a 74 club cab I built years ago and it solved the problem. Maybe it will help you
I agree with what has been stated so far. The steering needs to be centered prior to installation. The install needs to be taken apart and redone, correctly this time. I for one would appreciate you posting links to the exact Borgeson products you used.
