Belts and Pulleys
Old Oct 21, 2010 | 02:20 PM
Husker350's Avatar
Husker350
Default Belts and Pulleys
Alright, so on my 93' W350 I've been having a really high pitched screaming/squealing noise that I narrowed down to the pulleys on the engine. It starts screaming at high RPMs and I've replaced the idler pulley and the belt tensioner which seemed to make the problem a little better. But this morning when I fired her up it was a little chilly and I heard her squeaking, so I popped the hood and I think it was coming from the alternator, but I had the alternator rebuilt by a local shop so I'm at a loss at why it would be that, or what else it could be? and are you able to replace just the pulley on the alternator?
Old Oct 21, 2010 | 03:20 PM
pickfiddle's Avatar
pickfiddle
Ithe pulley on the alternTor might be turning, but the bearing or bushing at the back may have seized. The same happened on my truck last weekend. Do you hear it as soon as the truck starts?
Old Oct 21, 2010 | 03:24 PM
Husker350's Avatar
Husker350
I usually don't, but I heard it as soon as it started this morning. But it was fairly cold, so i thought that might be why I heard it this morning, but other times I usually don't when I first start it
Old Oct 21, 2010 | 03:31 PM
SEAL's Avatar
SEAL
Go to the parts store and get a can of belt dressing. While the engine is running spray the belt with the dressing. Be careful of the fan blades.
Old Nov 2, 2010 | 01:40 AM
BIG HOOK's Avatar
BIG HOOK
Make sure all of the pulleys (Alternator, crank, power steering, air pump, fan) are true to each other or in other words, all straight in relation to their respective belt routing. I've had reman-rebuilt alternators with pulleys that don't quite line up exactly with the fan/crank which can create a squeal, especially at high RPM's.
Old Dec 16, 2010 | 07:11 PM
rocketvette95's Avatar
rocketvette95
I have used that belt dressing and it makes a really big mess. The best thing I have found is baby powder. Put a little on the belt as it is spinning and the noise just goes away.
Old Dec 16, 2010 | 08:22 PM
pickfiddle's Avatar
pickfiddle
I've heard of using baby powder, but since I always find belt dressing to work just I need it I've never given it a try
Old Dec 17, 2010 | 09:21 AM
rocketvette95
The best thing about baby powder is that it dries up any oil or grease on the belt.
Old Dec 17, 2010 | 10:42 AM
Ironmower's Avatar
Ironmower
Baby powder? No kiddin. Learn sumtin new everyday. I use a bar of soap. It works OK, also.
Next time i'm try'n the baby powder. I too, make a mess of things with the proper belt dressing.
Thanks!
Old Dec 17, 2010 | 09:50 PM
rocketvette95
I have used Di-electric grease for a long time and that works great. But with baby powder it just don't make as big a mess.
